WAP4410N on a 3750G
Just setup a WAP4410N with two SSID's - one for guest and one for corporate side. Both are segregated by VLANs, however, I don't already have a guest VLAN defined, so I created one (VLAN 20).
However, this little WAP is hanging off a higher end Cisco 3750G switch, and it looks like I need to do a bit of config to actually ensure it provides proper Guest WiFi.
I was going to setup in the 3750G - DHCP Server for VLAN 20, DNS uses the ISP, point the gateway at the internal IP of the firewall.
But since the WAP4410N has one ethernet port, I am fitting the corporate and guest VLAN over the single switch port. Bad idea? I have found some config. to let both pass through, but then getting DHCP assigned to VLAN 20 on that port and passed properly to the firewall, I am not 100% sure of which direction is best to go (... looked at creating Private VLANs but seemed like a lot of work, thought it might be simpler).
Thoughts?
Re: WAP4410N on a 3750G
Hi Edward, since you have two ssids and two vlans, you need to allow encapsulation dot1q trunk on the switchport and allow the two vlans on that interface.
Cheers
Serge
Ok this is what I have for it, along with the DHCP Server in the switch, specifically for this guest VLAN:
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp excluded-address 192.168.20.240 192.168.20.254
interface GigabitEthernet1/8
description Cisco WAP4410N
switchport trunk allowed vlan 20,100
switchport mode trunk
switchport nonegotiate
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
mls qos trust cos
macro description cisco-wireless
auto qos voip trust
spanning-tree bpduguard enable
ip dhcp pool vlan20
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.247
interface Vlan20
description Guest Wi-Fi
ip address 192.168.20.247 255.255.255.0
(and VLAN 100 is 192.168.1.x)
Serge,
I did end up fixing DHCP assignments, however since the guest Wi-Fi is on VLAN 20, and only VLAN 100 and 200 are recognized by the edge router (which is managed by my ISP), the traffic would never go out to the internet.
Don't suppose I can NAT the traffic in the switch in any way, huh? Or some other solution to keep Guest WiFi from a WAP4410N isolated through a Cisco switch?
Hey Edward, as long as vlan 20 is allowed on that trunk port, why not to do just routing on the 3750 form that point and onwards?
764
