WCS 4.1 - How to delete events?
I was wondering if it's possible to delete all the events that get logged on WCS? There is no check box or select a command drop down list.
I have 10K+ events which I presume are being backed up every time.
I can delete alarms but not events.
Any clues?
1 ACCEPTED SOLUTION
Re: WCS 4.1 - How to delete events?
Alerts are kept until they are cleared and by default remain for 7 days before being purged from the database. WCS keeps the last 40,000 events in the system and clears them after 7 days. Events lead to alerts and events get cleared up after 7 days automaticly.
Let me know if this is what you are looking for.
-nael
-nael
ah ok, yeah that's fine - i did'nt actually check the dates on them, so I probably could have worked out that they are purged automatically.
thanks
476
