10-13-2009 04:14 AM - edited 07-03-2021 06:08 PM
I've been having some problems with the linux version of WCS. Sometimes, and I still don't know why the Database server stops. To activate it again I need to restart the service using the WCSStart script. Is anyone having similar problems? The service can work for two weeks or a month... then it just stops.
Best regards
10-23-2009 06:35 AM
10-27-2009 03:42 PM
Your database crashed.
Do you have other things running on your server?
On windows, A/V could be scanning WCS folder and make this happen, on Linux I have not seen it.
You can re-run a dbadmin checkshema but I suggest you open a TAC case at this point, this needs to be investigated more in details and you can actually upload your DB to TAC so they look at it.
01-25-2010 09:02 AM
I've been absent for a while and now I can see the proble I had remains. I noticed there was a new version 6.0.170.0 so I upgraded the WCS.
Anyway it didn't solve my issues, so I'll just open a TAC ticket.
Tiago
02-18-2010 11:48 PM
have you heard back from TAC yet?
my DB crashed again... would be nice to see this resolved...
02-19-2010 01:47 AM
I have opened a TAC ticket. They asked me to increase the logging level, and to send them the logs when it happens again. Since I did that the database hasn't crashed. I'm waiting for failure . It seems curious though that I think it never took so long before...
Best regards,
Tiago
02-19-2010 05:54 AM
Hey all,
I just wanted to let you know that the db issue has been seen before and is actively being worked in TAC and beyond. The issue is getting the info when it happens to try and determine the root cause which has been difficult. Please make sure to keep those debugs turned up with at least the Object Manager, General, Async and Database modules checked. What is needed is the transition from an "awake" state to the "crashed" state so capturing the logs during this time would be ideal.
