01-19-2012 03:39 AM - edited 07-03-2021 09:24 PM
Is there any way to configure alarm in WCS when the guest anchor tunnel goes down ? I dont see any alarms/messages in WCS if the guest tunnel between internal controller and guest controllers flaps or goes down.
Also, if i dont connect all 8 ports of the wlc5508 ports, i am getting the port down alarm constantly. but since i am using only 4 ports of the 5508, this is a false alarm for me. any way to disable or set threshold for port down alarm ?
regards
Joe
01-19-2012 03:58 AM
You should be able to see these. I know on the wlc, you will see an event log staring that the mobility path is down.
Scott Fella
Sent from my iPhone
01-19-2012 10:00 AM
hi Scott,
Nope, it doesnt come in the WCS. it does show in the trap logs in WLC about mobility path being down. but there is no such alarm category in WCS unfortunately which i see as a big disadvantage cos i am not able to track when the tunnels go down (even though wlc being up) and get an alert for that.
Any way to achieve this ?
regards
Joe
01-19-2012 10:07 AM
I don't know if it's not part of the alarms in WCS. You can always use syslog to timestamp that. I will take a look at my WCS later to see.
Scott Fella
Sent from my iPhone
01-29-2012 02:02 AM
Any update on this pls ?
regards
Joe
