WCS and Prime. Problem with Local Net Users
Hi all, I've got a 5508 running 7.0.116.0.  There are a lot of local net users stored on it for web-auth (1309).  I've been running it with WCS and found that not all users were backed up to it.  Only 7 appeared on the Security config page tab but if I logged in to WCS as Lobby Admin about 800 appeared.  I'm still missing about 500 web-auth accounts!
I've now got a parallel build Prime Infrastructure 1.3 machine built and can see exactly the same problem with that.  The 5508 is reachable but I can't get the config to sync and think it's because of the large number of web-auth accounts.
Anyone know if this is a bug in the WLC code?  Is there a limit to the number of "local net user" accounts that can be managed between WLC and WCS/PI?
I'm planning a code upgrade as I need to get some new APs on the system.  Just wondered if I might expect this to be fixed at the same time.
Hall of Fame Super Silver
Re: WCS and Prime. Problem with Local Net Users
I remember and there are other post out there you can search for, but there is a limitation to how many local net users you can view and or see in the config of the WLC. If you export the config and open it up in a text editor, do you see all the local net users or not. If not, I think you will be in a tough spot notated what especially if you have to RMA a WLC and have to restore the config. You will still be missing entries.
I would open a TAC case if that's the outcome you see as WCS/NCS and or Prime will not be able to sync that info.
-Scott
Found this thread which outlines the problem, lists it as a bug (but no ID) and says it's fixed in 7.2.103.0.
https://supportforums.cisco.com/thread/2185725
181
