WCS Guest ID/PW Auto Generate
In the WCS 4.0 PDF it states in Ch. 7 under the section Adding Guest User Accounts, "If you choose to auto generate, the user name and password fields will get populated." However, looking at the Guest User Template in Ch. 9 of the same guide, it seems that only the password gets auto generated. Can anyone verify which is the actual behavior?
1 REPLY
Re: WCS Guest ID/PW Auto Generate
The actual behavior is that it will auto generate the password. There is no option in the template nor in the lobby admin page to auto generate the username.
I created bug CSCsh18868 to either add this functionality or to correct the documentation.
143
