Community Member
WCS Report - Rogues on Wired LAN
Each WLC on our network shows "Rogues on Wired Network" from the Summary screen, however, checking these can be time consuming due to the number of WLC's in the network.
All of the WLC's are connected to a WCS so I was wondering whether a report for "Rogues on Wired Network" is available on the WCS??
I've spent a while looking around the WCS but can't find this information..
Re: WCS Report - Rogues on Wired LAN
You can use the switchport rogue trace feature. as explained on a similar post
Community Member
lavramov,
Can you please link to the post describing this?
173
