WCS Reports - SSID Filter
Hi All,
Currently running Cisco WCS 7.0.220.0 and when l go into Reports, Report Launch Pad and select a specific report e.g Client Traffic and l want to report by SSID , when l go to edit the Filter Criteria for SSID's, it is not showing all the SSID's ?
I currently do have some disabled and some that are enabled that are not showing in the List ?  Does anybody know why l am not able to display all SSID's in this list ?  Possibly something to do with Data Management ?
Thanks SG
Everyone's tags (6)
Hall of Fame Super Silver
Re: WCS Reports - SSID Filter
Did you refresh the config from the wlc?
-Scott
Hi Scott,
I am assuming you mean just doing a "refresh" from the top right hand side within the wlc ?  Which l have done numerous times..
That is all I can think of that would cause your issue. I'm also assuming that WCS version is equal or newer than the wlc.
-Scott
Yeah scott the wlc version is 7.0.116.0 and the WCS is 7.0.222.0
Just took a look at my lab WCS and all my SSID's show up there.  This is a lab WCS, so my WLC version is at 7.3 right now and I don't really use WCS, but it shows up.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
392
