WCS struggles, best practices?
Trying to start working with WCS that we have a demo of from Cisco, but struggling with how to get it to work the way I want. Is there anywhere that you can get a paper on how to best use it?
I was under the impression that it would make things very simple to do. We just got a couple controllers here at our main Datacenter, and want to use WCS to control them. I was under the impression that it would make administering them very easy.
We had one controller completely set up before putting in WCS and wanted to use WCS to program the second. I set up templates of how the controllers should be configured based on the first controllers configuration. Brought the second one online and expected it to fully program it like the first. However, I keep getting messages about not being able to do something because this radio is enabled, yet when I go disable the radio and try applying it again, it re-enables the radio and gives me the same message again.
Am I doing something wrong? Is there a better way to be using this system?
193
