Community Member
WCS using LDAP Groups
WCS Version 6.0.181.0 with LWAP 1242
Setting up a WLAN to use LDAP. I've read throught the configuration guide with little help. I was hoping to see if the community can assist. What I'm looking to do is use LDAP (AD) groups to get the VLAN that they work for. For example, account (group) when logged into wireless would be connected to the interface setup for the accounting department - VLAN1 (10.1.2.x). Where as a user from the Legal department logs into the system and gets an IP from the Legal Vlan (VLAN2 - 10.1.3.x).
I know that this works using ACS. Unfortunately our ACS is outdated and the appliance is on its last leg. Any help would be appreciated.
Everyone's tags (3)
1 REPLY
Silver
Re: WCS using LDAP Groups
I can't speak for LDAP specifically, but if you use RADIUS (MS IAS is free), you can define the Cisco VSAs needed to assign VLANs. A good if not old writeup is at the URL below. I believe it is for the most part still accurate.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008082d5b5.shtml
Cheers,
Eric
893
