WCS with TACACS, ACS necessity
Hello:
If I am using TACACS with WCS, is ACS a necessity for the security server or could I use other equipment to work?
Thank you very much
Nacho Montoya
Hall of Fame Super Silver
Re: WCS with TACACS, ACS necessity
If you want to authenticate to a radius server, then you can use IAS or any other radius server if you want. For WLC's you check the management user in the radius server.
-Scott
I have explain bad. I only want to know if when I am using a server with TACACS in a WCS enviroment, this server must to be an ACS or it could be a non-Cisco server.
Thank you
Nacho Montoya
You mean if you are using a server with TACACS in a LWAPP environment? WCS and the WLC's is authenticating to TACACS. You don't need ACS, but you need a radius server that supports TACACS. Hope this ansewers your questions.
-Scott
Thank you very much. This solves my question.
177
