cc
WDS and IAS Authentication
Hello !
I'm trying to configure 15 Access Points AP1231 as follow :
SSID1 mapped to VLAN 1 (also management VLAN) for Laptops. Encryption is WEP128 and Mac-authentication with Microsoft IAS server.
SSID2 mapped to VLAN 10 (phone VLAN)for phones 7921. Encryption is WEP128 and there is no authentication fo the phones.
I configure 1 AP as a WDS Master (priority 254). WDS registration works fine for all the 15 APs.
My problem :
it seems that when i activate WDS, MAC-authentication for ESSID1 doesn't work anymore (authentication failed for all the laptops).
Can you help me ?
1 REPLY
Silver
Re: WDS and IAS Authentication
WDS checks its local list for authentication . If the Mac address is not present it uses configured Radius server for authentication. Make sure Mac address is either in the Local list or Radius server. If you are using Radius server make sure Mac address is configured as user
113
