WDS & Infrastucture APs Authentication
I have a question about WDS.
The only authentication method that is available for WDS AP to authenticate the infrastructure APs is only LEAP
or we can use another EAP protocol? For example EAP-FAST?
Thanks in advance.
Re: WDS & Infrastucture APs Authentication
Hi Christos,
you should be able to go with eap-fast.
wlccp ap eap profile ?
  WORD  EAP profile name
This command ties an eap profile for wds ap authentication.
You have to configure that profile before :
AP1240(config)#eap profile test
AP1240config-eap-profile)#method fast
I didn't try to configure it myself but the commands are pretty clear I guess
Best Regards,
Nicolas
Please rate answers that you find useful
Thanks for your response Nicolas.
I'll test the configuration with EAP-FAST and i'll let you know..
Regards.
245
