Web-Auth page for mobile device ?
mr.marslin
Dears,
How to do the page that can check NB or Mobile device, and redirect the  difference login page ?
Need external server or can work in controller's custom page ?
Thanks.
Scott Fella
You can't have a separate WebAuth page just for mobile devices. Why should you want that since you can have a WebAuth use the same page.
-Scott
Scott Fella
The detection or what we call profiling is done after the device associates. Cisco ISE can profile and determine what type of device it is. However prior to association, there is no way to push devices to a specific splash page.
-Scott
Shaoqin Li
Level 3
Level 3
ISE 1.2 add mobile device portal into web page auth.
harvisin
Level 3
Level 3
This type of feature ISE 1.2 is supposed to support.
