Web Auth via ACS 5.3 and AD failing
Hi All,
I am looking to create a web auth network so users with non managed devices can connect to the wireless network via their AD credentials.
I have the users authenticating correctly via a PEAP/MS-ChapV2 solution so i know there is no issue with communications between ACS 5.3 and AD.
When they user fails authentication I receive the error message "22056 Subject not found in the applicable identity store(s)" yet i know the user is in the identity store based on successful authentications on the internal WLAN given above.
Ive tried changing the Web Auth on the WLC to CHAP, PAP and MD5CHAP to no avail.
Under the Access Policy created to link ACS to AD i have PEAP, MSCHAPv1 and 2 and CHAP configured as allowed protocols.
Ive tried different username modifications to no avail. I know the user is in the identity store.. ACS just cant find them..
Cheers
Darren
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: Web Auth via ACS 5.3 and AD failing
Well by default it should work using pap.
Scott Fella
Sent from my iPhone
-Scott
You should enable PAP on the Access service on your ACS.
Also make sure that you are using compliant L2 security measure , BTW do you have any mac filteration enabled or not?
Darren,
Are you trying to do webauth + 802.1x on the same ssid or just use webauth for the ssid?
-Scott
nope.
Just Webauth and authetication via RADIUS.
Im wondering if the AD cant access CHAP/MD5 auth requests.. I only have one Identity store created for the AD.
all other attributes look correct..
I do also have a TAC case running
Scott Fella
Sent from my iPhone
-Scott
I enabled PAP. Was trying not too but MS AD doesn't support CHAP.
No MAC or L2 security.
ISE is a future consideration, this solution is just the initial step for my client to get into shared and BYOD devices.
Cheers
887
