Web Login Encryption
tohoken
I know that when a user goes to login via the Web Login option that the authentication session is encrpted via SSL, I am OK with that. My question is after the user is authenticated, is there entire browser session encrypted or is "open"? I need the entire wireless session to be encrypted, not just the login session. How would I go about this?
Ken
diro
Only authentication is encrypted, you will need to use a vpn solution to encrypt the complete session
If this is for guest, the user has to protect their data if they want to use the f=guest network. You just put a terms of agreement on the webauth page and be done with it or else, like th eother poster stated... they VPN.
-Scott
