Hall of Fame Super Silver
WEB Login Fails
I have a client that is trying to authenticate users via IAS and AD account. AD logs show the authentification for the user 'wireless' has been granted. They get this error on the controller... It's the 2nd, 3rd and 4th from the top under user 'wireless'. What is invalid Service-Type 2?
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
  • Security and Network Management
2 ACCEPTED SOLUTIONS
Re: WEB Login Fails
I had similar issues but can't remember is it was service-type 2. The fix was to remove any radius framed attributes from IAS. For some reason we had framed attributes attached to the username in AD left over from NT4 days. The only attribute I send is service-type 6 value "login".
Re: WEB Login Fails
on the EAP profile, under authentication, check to make sure the option is set to Login, and not Framed. Framed is the default setting on IAS, and the Cisco devices want this set to Login.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Silver
Re: WEB Login Fails
You may be running into a bug here. The bug-Id is: CSCed54962
Re: WEB Login Fails
Re: WEB Login Fails
Re: WEB Login Fails
Attached document for your help (screens of my radius IAS server), I had the same problem with IAS and Active Directory, this integrated with web authentification and WLC.
it solves it, thankyou very much per the help.
173
