Web redirect not working on MAC OS X WLC 5508
I have a problem with Mac OS X-users. When connecting to the guest-network, the Mac does not get redirected to the login-web.
I have tried to manually type in the url and IP-adress to the login-page, but cannot reach it. It works with all other devices.
Code: 7.6.130.0 Hardware: Cisco 5508
Grateful for any input on the matter.
Fabian
Is there any guest anchoring
Is there any guest anchoring in this scenario?
Have you verified that your client is receiving DNS and can do nslookups?
Is this with all MAC users or only a select subset e.g. Yosemite only machines?
What is the virtual IP you are using?
Alex
Problem solved. It was the
Problem solved. It was the mac os that didn't get the right DNS-servers, so it couldn't do a nslookup.
Easy one, but didn't see it until you mentioned it, so thank you!
Glad I could help!
Glad I could help!
Alex
142
