Webauth Redirect Issue WLC 7.2
We have been using Passthrough with Email input on our Guest network for a while.  We use the Internal (Default) Web Authentication Type with a URL redirection after login and a custom Headline/Message and Logo on the login page.  This worked fine, I even made a few changes recently, until we attempted to switch from https: to http: on the login page today.  This was done using the config network web-auth secureweb disable command in the Command Line.  After making this change and rebooting the controller, the login/redirect page loads using http: (it redirects after entering an email address) but the graphics (banner at the top and logo) do not.  Looking at the source code, everything looks the same.  I am sure that it is using the Internal login page, as I tried using Customized and External, neither of which worked.  Has anyone run into this problem before?  Thanks.
1 REPLY
In order to have the web page load properly, it is not sufficient to set the web-authentication type as customized globally in the Security > Web Auth > Web login page. It must also be configured on a particular WLAN . In order to do this, complete these steps:
    Log into the GUI of the WLC.
    Click on the WLANs tab, and access the profile of the WLAN configured for Web-authentication.
    On the WLAN > Edit page, click the Security tab. Then, choose Layer 3.
    On this page, choose None as the Layer 3 Security.
    Check the Web Policy box, and choose the Authentication option.
    Check the Over-ride Global Config Enable box, choose Customized (Downloaded) as the Web Auth Type, and select the desired login page from theLogin Pagepull down menu. Click Apply
227
