Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WebAuth - Working intermittently
I have a guest WLAN setup and have WebAuth with the default web page being used. It seems that after a few hours, the WebAuth stops prompting users on that WLAN for the guest creds and lets them access the internet without having to log in.
I go into the WLCs (WiSM in 6500) and see all my settings are there, but it does not work.
Without changing any settings, I click the save option and it starts working again. It's almost like the settings are there but keep getting unapplied after a time. Weird... It just started doing this and had been working fine for months. I haven't changed anything so I am stumped.... Any ideas?
Ed
Silver
Re: WebAuth - Working intermittently
"Have you rebooted your computer?"
Seriously, if your controllers just spontaneously start acting wonky after extended service, I'd try a quick reboot and see if that clears it up.
No, I understand why you recommended that and yes, I have tried that. I was thinking the creds were cached or something, but that wasn't the case. We have the WiSM setup to always prompt when you disconnect from the wireless and re-connect.
Thanks for the idea though!
Ed
What version of code are you now running and are the clients truly guests or internal users with AD credentials using the guest access network?
Thanks for the response... Below is the info.... Also, yes it is using true webauth, not AD for the guest network. We are using the built-in internal webauth page and not the customized one etc....
Thanks!
Ed
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 4.1.171.0
RTOS Version..................................... 4.1.171.0
Bootloader Version............................... 3.2.150.6
Build Type....................................... DATA + WPS
System Name...................................... C6500-WiSM1
System Location.................................. C6500
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.4
System Up Time................................... 12 days 10 hrs 7 mins 4 secs
Configured Country............................... US - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +35 C
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 3
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 2
Update your code to at least 4.2.130 and your boot loader as well.
Sounds good! Thank you... I will do that!
Ed
248
