WEP Showing up in Radius Authentication
Greetings,
i have couple of WAP4410N wireless access points, i have tried to setup connection control (MAC Filtering) with RADIUS server.
i have also disabled Wifi Security, but its showing wifi is protected with WEP upon scan.
i cannot connect any device coz what is WEP key ?? which i never setup
even i have changed security to WPA / WPA2, even correct key is not working.
RADIUS server itself is working fine (free radius) i have been able to test it from radtest command on linux as well as some windows applications.
please help
Everyone's tags (1)
1 REPLY
Bronze
Hi,Make sure your APs are
Make sure your APs are running with latest firmware release and then change your access-points wireless security mode to WPA-Enterprise and then try use Radius Server .
62
