What MSE 3350 versions are compatible with PI 1.4.0.45?
Sounds simple, but on CCO the latest MSE version I see listed for the 3350 is 7.3.101, and its release note compatibility matrix only says 1.2.0.103. Is the 3350 no longer supported with PI 1.3 and above?
look here:
http://goo.gl/pto6qv
Amjad
Rating useful replies is more useful than saying "Thank you"
Thanks, that looks promising! I had looked at http://www.cisco.com/en/US/customer/docs/net_mgmt/prime/infrastructure/1.4/release/notes/cpi_rn_14.html#wp103402
which seems to suggest the 3350 will not work with PI 1.4.
238
