When I connect to ASA from L2 S/W using IPSEC Tunnel .
Hi.
When I connect to ASA from L2 Switch using IP sec Tunnel, I invocked the cli command, the session hang up, and then I can't L2 Switch , If I want to connect to L2 Switch again, I must reload L2 Switch.
Is this a ASA Security function?
I attached the configuration my customer site. the public ip was deleted due to security issue.
P.S What is a below command?
threat-detection basic-threat
threat-detection statistics access-list
1 REPLY
Silver
Re: When I connect to ASA from L2 S/W using IPSEC Tunnel .
To view the threat detection configuration, use the show running-config threat-detection command in privileged EXEC mode.
show running-config [all] threat-detection
option : all -- (Optional) Shows all threat detection commands, including the commands you have not changed from the default. For example, you can view the default rate limits for the threat-detection basic-threat command.
197
