When starting WCS I get a Java error
     could not find the main class. Program will exit
Re: When starting WCS I get a Java error
Version is 4.2.128.0
I had this issue on 6.0 code, it was actually a Java problem.  I had to install java manually or reinstall WCS on a clean windows box.  Called TAC on it and they were totally stumped as to why the issue happened.
I did reinstall JAVA but that didn't fix the problem.
284
