Why doesn't AP 1131 authenticate station using EAP WPA2?
I've got one AP 1131ag, a Zyxel AP and Windows 2003 server running IAS. The Zyxel works as expected with Radius set to the server and WPA2 (RADIUS server set on the AP 192.168.1.7 port 1812, stations running Windows 7 EAP, MSCHAPv2, WPA2 AES).
However trying to set the same on Cisco AP 1131ag always fails. I have aleready tried numerous guides usig GUI to configure EAP WPA2 but no luck so far.
The event log on the Windows 2003 server says that the stations trying to connect to the network using Cisco AP are allowed to do so (as they are in case of the Zyxel AP), but they are still refused by the Cisco AP (Station xxxx.xxxx.xxxx Authentication failed.)
Any hint on what I might be doing wrong appreciated.
Current configuration : 3494 bytes
! Last configuration change at 13:54:37 CET Fri Mar 14 2014 by Cisco
! NVRAM config last updated at 13:54:37 CET Fri Mar 14 2014 by Cisco
version 12.4
no service pad
service password-encryption
hostname ap12_gymjablonec
logging rate-limit console 9
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa group server radius rad_eap
 server 192.168.1.7 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa group server radius rad-eap
aaa group server radius rad_eap2
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap2
aaa authentication dot1x default group radius
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone CET 1
ip domain name sportgym.cz
dot11 syslog
dot11 ssid RANDANET-X
   vlan 5
   authentication open eap eap_methods1
   authentication key-management wpa version 2
   guest-mode
power inline negotiation prestandard source
dot1x timeout reauth-period server
username Cisco privilege 15 password 7 xxxxxxxxxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 encryption vlan 5 mode ciphers aes-ccm
 ssid RANDANET-X
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.5
 encapsulation dot1Q 5
 no ip route-cache
 bridge-group 5
 bridge-group 5 subscriber-loop-control
 bridge-group 5 block-unknown-source
 no bridge-group 5 source-learning
 no bridge-group 5 unicast-flooding
 bridge-group 5 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 encryption mode ciphers tkip
 no dfs band block
 channel dfs
 station-role root
 bridge-group 1
interface FastEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface FastEthernet0.5
 no ip route-cache
 bridge-group 5
interface BVI1
 ip address 192.168.7.21 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.7.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging history size 100
radius-server local
  no authentication eapfast
  no authentication leap
  no authentication mac
radius-server attribute 32 include-in-access-req format %h.%d
radius-server host 192.168.1.7 auth-port 1812 acct-port 1813 key 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
sntp server 192.168.1.9
end
    • Security and Network Management
    Everyone's tags (1)
    Hall of Fame Super Silver
    You need to post your show
    You need to post your show run-config.  From the CLI, you can configure WPA2/AES:
    dot11 ssid <ssid>
       authentication open
       guest-mode
       wpa-psk ascii <pre-sahred key>
    Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
    Here is the current config
    Here is the current config:
    version 12.4
    no service pad
    aaa new-model
    dot11 syslog
       vlan 5
       guest-mode
    bridge irb
     no ip address
     no ip route-cache
     ssid RANDANET-X
     station-role root
     bridge-group 1
     no ip route-cache
     bridge-group 5
     no ip address
     no ip route-cache
     shutdown
     no dfs band block
     channel dfs
     station-role root
     bridge-group 1
     no ip address
     no ip route-cache
     duplex auto
     speed auto
     bridge-group 1
     no ip route-cache
     bridge-group 5
    interface BVI1
     no ip route-cache
    ip http server
    radius-server local
    bridge 1 route ip
    line con 0
    line vty 0 4
    end
    145
