06-18-2014 10:29 AM - edited 07-05-2021 01:02 AM
Dear Sirs!
I use Cisco AiroNet and have multissid WiFI
What can I filter users by MAC address only on specific SSID?
Thanks!
06-18-2014 03:31 PM
Filter MAC addressed against specific SSID? Then you do this on the switch. You put a MAC-based ACL and apply it to the VLAN interface you do not want the clients to go.
06-19-2014 03:48 AM
Tnanks!
I will try it...
06-23-2014 05:20 AM
Mac address-table xxxx.xxxx.xxxx static
vlan ### drop
07-09-2014 08:50 AM
vlan ### drop
In this sring, xxxx.xxxx.xxxx it is allowed MAC?
and vlan ### drop it is entered in global config?
Thanks!
08-06-2014 08:42 AM
Please check the below detailed document for MAC filtering against specific radio and SSID.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-2_15_JA/configuration/guide/i12215sc/s15filt.html
