WiFi MBSSID and MAC filtering
Dear Sirs!
I use Cisco AiroNet and have multissid WiFI
What can I filter users by MAC address only on specific SSID?
Thanks!
------------------------------------------------------ Helping seriously ill children, all together. All information about this, is posted on my blog
  • Security and Network Management
Hall of Fame Super Gold
Filter MAC addressed against
Filter MAC addressed against specific SSID?  Then you do this on the switch.  You put a MAC-based ACL and apply it to the VLAN interface you do not want the clients to go.
Tnanks!I will try it...
Tnanks!
I will try it...
Mac address-table xxxx.xxxx
Mac address-table xxxx.xxxx.xxxx static
vlan ### drop
vlan ### drop
In this sring, xxxx.xxxx.xxxx it is allowed MAC?
and vlan ### drop it is entered in global config?
Thanks!
Bronze
Hi,Please check the below
Please check the below detailed document for MAC filtering against specific radio and SSID.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-2_15_JA/configuration/guide/i12215sc/s15filt.html
377
