wIPS MSE....
yprasannas
After installing wIPS(MSE) and adding to WCS...where do we see the alerts.
I added 10 AP's to WLC and a AP in monitor mode. Testing SSID with wrong credentials to see any alerts.. but dont see anywhere.
How to test the wIPS?
Lucien Avramov
Level 10
Level 10
What version of WCS and what version of MSE are you running?
Have you made sure that you are using a supported MSE version for the WCS version you have?
Go and check the release notes:
http://www.cisco.com/en/US/products/ps6305/prod_release_notes_list.html
http://www.cisco.com/en/US/products/ps9742/prod_release_notes_list.html
Yes the code is supported.
1. WLC has 100 AP's spread over 20 locations.
2. Monitor AP's are installed in 5 public locations and other 15 are not needed.
3. To avoid duplicate alerts if I disable alerts from WLC then I will be getting alerts only from 5 monitor AP's.
4. How can I get partial alerts from WLC? Get alerts from WLC where monitor AP's are not present and get alerts only from monitor AP's.
