Community Member
Wired guest Anchor WLC and CWA
I have a customer who wants to anchor all guest traffic from the wired network to the DMZ WLC.  Is the only way to do this to have a local WLC which you VLAN wired guest traffic to, then tunnel to the DMZ WLC?
Does this scenario work ok with CWA? I assume  it does as the switch will authenticate using ISE, after that it is just logically segregated traffic and the controllers don’t do any authenticating, they just pass the traffic through.
1 ACCEPTED SOLUTION
Silver
yes its works fine i would
yes its works fine i would suggest you check the Cisco smart business arch. design guides
1 REPLY
Silver
108
