wireless access point 1200 series.
Dear NetPro,
i've a major problem about the wireless, my client has faced about the wireless problem which is not authenticate with the Access Point, i have checked the access point, status everything was working fine, even logs show debugging ......
what can i do now ?
please reply , urgent.
Jack
Green
Re: wireless access point 1200 series.
What are the clients, and which NIC are they using?
What versions of software are you using on the AP and clients?
What variety of Authentication are you using?
Can you connect with no encryption / authentication?
What authentication and encryption have you tried?
Please let us know ....
Good Luck
Scott
Dear Scott,
i am using Cisco wireless card 802.11b version 6.0
i am using 12.3(7)JA1 for Access Point.version 6.1.002
i am using LEAP authentication.
198
