Wireless AP native vlan and switch trunk
I am unable to ping my ap, i think it is due to the multiple vlan issues, can provide some advise, my config for the ap and switch is as below
AP Config
version 15.2
no service pad
service password-encryption
hostname hostname
logging rate-limit console 9
enable secret 5 $1$ZxN/$eYOf/ngj7vVixlj.wjG2G0
no aaa new-model
ip cef
dot11 syslog
dot11 ssid Personal
   vlan 2
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 070E26451F5A17113741595D
username Cisco password 7 1531021F0725
bridge irb
interface Dot11Radio0
no ip address
encryption vlan 2 mode ciphers aes-ccm tkip
ssid Personal
antenna gain 0
stbc
beamform ofdm
station-role root
no dot11 extension aironet
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0.100
encapsulation dot1Q 100 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
ssid Personal
antenna gain 0
no dfs band block
stbc
beamform ofdm
channel dfs
station-role root
interface Dot11Radio1.2
bridge-group 2
interface Dot11Radio1.100
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.2
bridge-group 2
interface GigabitEthernet0.100
bridge-group 1
interface BVI1
ip address 192.168.1.100 255.255.255.0
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
password 7 01181101521F
login
transport input all
end
Switch Port config
interface FastEthernet1/0/10
switchport trunk native vlan 100
switchport mode trunk
Hall of Fame Super Silver
Re: Wireless AP native vlan and switch trunk
That looks fine. Is vlan 100 being passed all the way to the core? If you connect a laptop to the same switch but on vlan 100, can you ping the AP.
-Scott
Thanks for the reply, if I am on vlan 100 i can ping the AP but if I am on another vlan i am unable to do so, the vlan routing is fine, not sure why, any clue ?
If your on vlan 100 it works but if your not on vlan 100 it doesn't? Then routing is not working. From the AP or the laptop on vlan 100, you can ping vlan 100 gateway correct but nothing else. If so, check your routing.
-Scott
I will re-check the routing again but could it be some bridging issues ?
no ip address
duplex auto
speed auto
**** unable to put up this command on the giga port
bridge-group 1
I try to put this command on the gigaethernet port but it does not allow me, could this be the bridging  issue ?
The BVI interface is what needs an IP address. If a laptop in an access port vlan 100 on the same switch can't ping the gateway or other gateways, then you have a routing issue or vlan 100 is not being passed to the core.
-Scott
how can i check if vlan 100 is pass to the core or not ? I think i did a test before by puting a laptop on vlan 100 and another laptop on another vlan 200, the laptop on vlan 200 is able to ping the laptop on vlan 100 but not the access point (need to re-confirm)
thanks for the help
Need to makes sure vlan 100 is defined on all the switches that lead back to the core. If you can ping the AP from a laptop on vlan 100 on the same switch then nothing is wrong with the AP since that is layer 2. Layer 3 seems to be broke.
-Scott
300
