Community Member
wireless authenticaiton with ISA
I have implemented a WISM on 6500, with WLAN defined for windows client using PEAP. Authenticaiton server is MS IAS server with SSL certificate installed.
Now the users are connecting and authenticated fine.
Problem;
When the user disconnect and try to re-connect, it never ask for user credentials. It just connects. I want to disable this and want to enter user credentials each time user tries to connect.
How can I achieve this ?
1 REPLY
Silver
Re: wireless authenticaiton with ISA
Here is the URL for the PEAP Under Unified Wireless Networks with Microsoft Internet Authentication Service (IAS). Following guide will help you for configuration.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml
304
