Wireless authentication .... LDAP or Radius?
Greeting everyone
We have to setup a wireless infrastructure for a customer and we have the following requirement:
Authenticate users and their Corporate laptop against LDAP so basically if you bring your personnel laptop it won`t work cause it`s not part of the domain.
So the big question is Can we allow on AD devices to authenticate via LDAP or via RADIUS?
Thanks a lot for the help
3 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: Wireless authentication .... LDAP or Radius?
Here is a doc for IAS... on step 19, you would "ADD" another policy "Computer Group" or "Windows Group" and select your computer OU.  This is a nice step by step guide.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml#chap2
-Scott
Radius is the best way in my opinion. Guest users I would use the wlc for local login.
-Scott
You can do both, but your better off using a raidus server and authenticating via machine authentication.  This way users can't just enter their AD credentials on their personal devices.  So as long as you have your computers joined to the domain, you will be able to authenticate using the computer group.
http://pcloadletter.co.uk/2011/07/11/cisco-wifi-active-directory-auth/
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00801df0e4.shtml
-Scott
Hi Scott Thanks for the answer so using ldap users can even use their personnal devices but they only have to enter their username and password !
Can you point me to a document on how to authenticate against Machines container using Radius and IAS
Thanks a lot Scott awesome answer
-Scott
Awesome docs !
Thanks Scott
No problem... Jut keep us posted if you run into any issues.
-Scott
Scott thanks for your help
I`m actually going to use Radius since with LDAP integration it`s only available for Web authentication ...
Correct me if i`m wrong ?
-Scott
Thanks Again for your answer Scott
So there is no direct intergration to LDAP for user authentication ... i guess RADIUS will be always my first choice then
If you really want to you can, but I personnaly won't do it that way.  Here is a link you might want to look at.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080a03e09.shtml
https://supportforums.cisco.com/thread/2055640
-Scott
1522
