Wireless connection to 871w intermittent connection
Im having a very serious problem on my wireless connection, my laptop keep on disconnecting, even my wifi phones (nokia), below are the logs on my router
Nov 24 12:35:16.976: *** Not encrypted dot1x packet from 0013.02b7.811b has been
discarded
Nov 24 12:35:17.228: %DOT11-7-AUTH_FAILED: Station 0013.02b7.811b Authentication
failed
Nov 24 12:35:18.336: *** Not encrypted dot1x packet from 0013.02b7.811b has been
discarded
currenty im running a c870-advipservicesk9-mz.124-9.T
below are my sample configuration
ip dhcp excluded-address 172.25.254.1 172.25.254.10
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp pool SecureZone
import all
network 172.25.254.0 255.255.255.0
default-router 172.25.254.1
domain-name securezone.mcm.com
dns-server 218.186.1.38 202.156.1.58
lease 4
ip dhcp pool InternalUsers
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
domain-name internalusers.mcm.com
lease 4
ip dhcp pool GuestUsers
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
domain-name guestusers.mcm.com
interface Dot11Radio0
no ip address
encryption vlan 10 mode ciphers tkip
encryption vlan 20 mode ciphers tkip
encryption vlan 30 mode ciphers tkip
ssid GuestUsersV30
vlan 30
authentication open
authentication key-management wpa
wpa-psk ascii 7 06110627451F5B4A51
ssid InternalUsersV20
vlan 20
authentication open
wpa-psk ascii 7 1059001F0C46405858
ssid SecureZoneV10
vlan 10
authentication open
guest-mode
wpa-psk ascii 7 02110D5D02575D7218
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
no dot11 extension aironet
no cdp enable
interface Dot11Radio0.10
encapsulation dot1Q 10
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface Dot11Radio0.20
encapsulation dot1Q 20
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 spanning-disabled
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
interface Dot11Radio0.30
encapsulation dot1Q 30
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 spanning-disabled
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
interface Vlan1
no ip address
interface Vlan10
description Secure Zone Gateway
no ip address
ip nat inside
ip virtual-reassembly
bridge-group 10
interface Vlan20
description Internal Users Gateway
no ip address
ip nat inside
bridge-group 20
interface Vlan30
description Guest Users Gateway
no ip address
ip nat inside
bridge-group 30
interface BVI10
description Bridge to Secure Zone Network$FW_INSIDE$
ip address 172.25.254.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
interface BVI20
description Bridge to Internal Users Network$FW_INSIDE$
ip flow ingress
ip flow egress
ip nat inside
interface BVI30
description Bridge to Guest Users Network
ip address 192.168.2.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
Hope anyone can help me.
Marlon
Silver
Re: Wireless connection to 871w intermittent connection
The most common reasons are the user has entered the wrong password or the radius server maybe unavailable.
For the further assistance follow the URL
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_tech_note09186a008024aa4f.shtml
I have the same issue with my 871w, I know what the issue is though. I havent had much time to look to deep into it.
There is an issue with your BVI interface reconstructing packets. You also might have a couple crash logs on your flash.
*May 11 04:42:26.440: %IP_VFR-3-SYSTEM_ERROR: BVI1: IP VFR System failure - Unable to create fragment chain
*May 11 04:42:26.440: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=83DC0E6C, count=0, -Traceback= 0x8089554C 0x802F5DE0 0x811FA798 0x811FAD04 0x811FBEC8 0x811FD748 0x80BB56E8 0x80784234 0x80378B58 0x80399C3C 0x8039D594 0x80385E8C 0x804642F4 0x80353748 0x800827B8 0x800827B8
*May 11 04:42:26.444: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=83DC7C88, count=0, -Traceback= 0x8089554C 0x802F5DE0 0x8036F67C 0x80784248 0x80378B58 0x80399C3C 0x8039D594 0x80385E8C 0x804642F4 0x80353748 0x800827B8 0x800827B8 0x80353808 0x8170336C
Keeps going on like that for a while...
327
