wireless encryption between AP and Laptop
mmaron
Is there any type of encrytion between an access point and a pc? is the data encrypted ?
ankbhasi
Hi Friend,
It depends on how you configure your WLAN/SSID. If it is configured for open authentication then there is no encryption and data is not secured between AP and clients but if you configure your SSID/WLAN and client with encryption technology as WPA1/2 with TKIP/AES you can get a secure communication between client and APs.
See if this link helps you
http://www.cisco.com/univercd/cc/td/doc/product/wireless/control/c44/ccfig41/c41sol.htm#wp1040053
Ankur
*Pls rate all helpfull post
