Community Member
Wireless Guest Access through 4404, bandwidth limiting.
We are currently running a Guest SSID on our network and pumping it out through a DSL line and it's working great. However, as we've expanded our LWAPP conversion and offering the Guest SSID to more area's, my DSL line has become very saturated and we're not in area that can get a bigger pipe. IS there a radius attribute that I can use through ACS that the 4404 controllers will recognize to limit the users bandwidth? In the past when using an opensource solution for guest access (ChiliServ and FreeRadius) I was able to use the WiSPr attributes:
WISPr-Bandwidth-Max-Down
WISPr-Bandwidth-Max-Up
and it worked pretty well. What does one do in this case? I know I can pass Airespace attributes with ACS, but I don't see anything that will minimize bandwidth unless I'm just not understanding the QoS tagging.
Re: Wireless Guest Access through 4404, bandwidth limiting.
We have used a very inexpensive box from a third party vendor called a NetEqualizer. This box also provides CALEA reporting to the federal government and fulfills your CALEA hardware requirements. It is extremely easy to use and costs less than the server box you would run free radius on.
http://netequalizer.com/
Community Member
Return the airespace attribute from ACS is one option another one is craete guest user in local netuser DB and assign the guest role. That guest role should be already excist in controller with preferd bandwidth settings. I suggest you this as the solution than returning from ACS.
Community Member
Is there away to select this role and use the ACS? I prefer to continue to use our ACS as our central point of all authentication instead of spreading it around.
Community Member
you can return it from ACS using the the airespace attributes. Enable "aaa overide" in the wlan will do.
Which is your controller image based on that i can suggest you which will be better solution for you.
Community Member
We've just moved to 5.2.178.0. So if I'm understanding you correctly, I can pass the Guest Role via ACS air-space attributes? Which attribute would I use for this? I know on the Airspace-QoS-Level I can select Bronze to Uranium but other then that I'm not sure.
Thank you for your help.
Community Member
using ACS for guest role is not straight forward. You may need to add it using a dictionary file and import it using some utility.
That is the reason i suggested you local DB for the guest role. Another radius server which support guest role retrn to controller is SBR(third party) which has this support be default. Hope this will help you.
In between i dont find any security threat in configuring it in local DB and map to guest role.
SBR= Steel Belted RADIUS from Funk/Juniper.
Community Member
Is there a configuration document you can hook me up with?
Community Member
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080891919.shtml#tc6
This document will help you to configure that. Hope this will solve your issue and let me know how it goes
Pls Note: We can send the role information from a radius server also on a per-user basis forusers using web authentication only. This role information cannot be used for 802.1x
authentication of the clients.
Community Member
Thank you so much for the information. I do have another question however. I have these options and have been using them. However, I'm guessing that I can insert the role into the airspace-qos-level and have it as a selectable option instead of the default bronze through uranium that i do currently?
Community Member
As i mentioned these roles can be used only for guest users. For normall 802.1x u cant use them.
I hope i answered your question
Community Member
I am using webauth, but where does the role information go into the radius server, specifically ACS? In the document it states how to install the airspace vsa's. In ACS 4.2 I already have the airspace vsa's available i.e. airspace-qos-level. Is this the attribute that is needed to send the Role inforamtion? If not, can you please provide this attribute? That's all I'm looking for is as to what attribute is needed by the controller to receive the role information. from a per-user level or whatever. I do have the vsa's working since my original post and having upgraded the controller software (before it would stop sending traffic) so I can now pass the airspace-qos-level if this is the right attribute, but the most important thing about this attribute is that I only have Bronze to Uranium listed in ACS. If this is the attribute to send role information? How do I add more to this list as it is a drop down box not a text box where I can put in my own information.
Community Member
The attribute name should be "Aire-role-Name". This attribute can return the guest role name to controller and controller will map the corresponding role defined in DB.
Community Member
I have attached a screen shot
This will help you i think
Community Member
Thank you. NOW, how do insert this attribute into ACS 4.2 which already has airspace vsa's installed
[026/14179/002] Aire-QoS-Level
[026/14179/003] Aire-DSCP
[026/14179/004] Aire-802.1P-Tag
[026/14179/005] Aire-Interface-Name
[026/14179/006] Aire-Acl-Name
These are the ones I have available. since Airespace is already built into this version ACS how do I go about adding an attribute to it?
Community Member
Ahh, see that screen shot is exactly what I'm looking for. I just don't know how to get that attribute available. I know the document you gave me showed teh example of installing the airspace vsa, but like I mentioned I already have several just not hat specific one that came pre-built in ACS 4.2? Can I add a single attribute to the list somehow?
Community Member
Please follow the document i provided earlier to add this attribute.
Jibin
Community Member
The document you referenced is not the same document that is shown in your screen capture. Please send me a link to the document that you captured from.
Community Member
Sorry i cant send you that document due to some reasons. Please follow the document i already provided and add the attributes. It will work.
Community Member
Thank, I shall do my best. I notice that aire-role-name is attribute 11 for airespace attributes, what other attributes are available?
Community Member
Hello All.
I was concerned about following the document provided and overwriting and potentially messing up my current airespace VSA's so I contacted TAC for extra help. The engineer stated they considered this a bug (CSCsy03746)and sent me a script to add extra attributes for airespace. I've attached a screen shot of those available. I'd highly recommend that anyone interested to contact TAC as this script is only available through them.
Community Member
Is this patch going to be made publicly available for ACS 4.2 or do I still need to contact TAC? Also with ACS 5.1 the additional attributes shown in the above screen shot are still missing is there a patch available for ACS5.1 to get the additional attributes? TIA
2634
