How can I configure the WLC to recognize a WLAN (subnet)across a WAN link? If I create a WVLAN interface on the WLC for the remote subnet, the WVLAN is local to the WLC. I thought I needed to do some sort of config using REAP, but when I select REAP under AP mode on the WLC, I get an error: REAP mode not supported on this AP. I am using AP model AIR-LAP1131AG-A-K9. Lost! Thank You!
