Wireless Lan Controller RRM Load client thresholds question
Hi all
I facing a problem of Load thresholds counter incorrect in my WLC-5508. I had received Snmptrap-log of Load Profile failed after this value was changed to 25 (default is 12), But in this moment that association client was very lower (maybe 6 or 9). I have the some question:
1. What is it the trigger value for Load thresholds ?
2. Why is it trigger then send snmptrap but this moment that value was mismatch with Load Information ?
Can any one help me ?
///////////////////////////////////////////// LOG //////////////////////////////////////////////////////////
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... WLC-5508-1
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. AP SSO
IP Address....................................... 192.168.0.1
Last Reset....................................... Software reset
System Up Time................................... 39 days 2 hrs 14 mins 1 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
(Cisco Controller) >show ap auto-rf 802.11b AP1
Load Information
    Load Profile................................. PASSED
    Receive Utilization.......................... 0 %
    Transmit Utilization......................... 2 %
    Channel Utilization.......................... 62 %
    Attached Clients............................. 8 clients
(Cisco Controller) >show ap config 802.11b AP1
Cisco AP Identifier.............................. 218
Cisco AP Name.................................... AP1
Country code..................................... US  - United States
Regulatory Domain allowed by Country............. 802.11bg:-A     802.11a:-A
AP Country code.................................. US  - United States
AP Regulatory Domain............................. -A
Switch Port Number .............................. 1
IP Address Configuration......................... Static IP assigned
Domain...........................................
Name Server......................................
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Disabled
Ssh State........................................ Disabled
Cisco AP Location................................ default location
Cisco AP Floor Label............................. 0
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................ WLC-5508-1
Primary Cisco Switch IP Address.................. 192.168.0.1
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W  Version .................................... 7.4.100.0
Boot  Version ................................... 12.4.25.1
Mini IOS Version ................................ 7.5.1.73
Stats Reporting Period .......................... 180
Stats Collection Mode ........................... normal
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-CAP2602I-T-K9
AP Image......................................... C2600-K9W8-M
IOS Version...................................... 15.2(2)JB$
Reset Button..................................... Enabled
AP Certificate Type.............................. Manufacture Installed
AP User Mode..................................... AUTOMATIC
AP User Name..................................... Not Configured
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 28 days, 03 h 07 m 21 s
AP LWAPP Up Time................................. 14 days, 23 h 44 m 43 s
Join Date and Time............................... Thu Mar 27 17:21:30 2014
Join Taken Time.................................. 0 days, 00 h 00 m 16 s
Attributes for Slot  0
    Radio Type................................... RADIO_TYPE_80211n-2.4
    Administrative State ........................ ADMIN_ENABLED
    Operation State ............................. UP
    Radio Role .................................. ACCESS
    Radio Mode .................................. Local
    CellId ...................................... 0
    Station Configuration
      Configuration ............................. AUTOMATIC
      Number Of WLANs ........................... 1
      Medium Occupancy Limit .................... 100
      CFP Period ................................ 4
      CFP MaxDuration ........................... 60
      BSSID .....................................
      Operation Rate Set
        1000 Kilo Bits........................... MANDATORY
        2000 Kilo Bits........................... MANDATORY
        5500 Kilo Bits........................... MANDATORY
        11000 Kilo Bits.......................... MANDATORY
        6000 Kilo Bits........................... SUPPORTED
        9000 Kilo Bits........................... SUPPORTED
        12000 Kilo Bits.......................... SUPPORTED
        18000 Kilo Bits.......................... SUPPORTED
        24000 Kilo Bits.......................... SUPPORTED
        36000 Kilo Bits.......................... SUPPORTED
        48000 Kilo Bits.......................... SUPPORTED
        54000 Kilo Bits.......................... SUPPORTED
      MCS Set
        MCS 0.................................... SUPPORTED
        MCS 1.................................... SUPPORTED
        MCS 2.................................... SUPPORTED
        MCS 3.................................... SUPPORTED
        MCS 4.................................... SUPPORTED
        MCS 5.................................... SUPPORTED
        MCS 6.................................... SUPPORTED
        MCS 7.................................... SUPPORTED
        MCS 8.................................... SUPPORTED
        MCS 9.................................... SUPPORTED
        MCS 10................................... SUPPORTED
        MCS 11................................... SUPPORTED
        MCS 12................................... SUPPORTED
        MCS 13................................... SUPPORTED
        MCS 14................................... SUPPORTED
        MCS 15................................... SUPPORTED
        MCS 16................................... SUPPORTED
        MCS 17................................... SUPPORTED
        MCS 18................................... SUPPORTED
        MCS 19................................... SUPPORTED
        MCS 20................................... SUPPORTED
        MCS 21................................... SUPPORTED
        MCS 22................................... SUPPORTED
        MCS 23................................... SUPPORTED
      Beacon Period ............................. 100
      Fragmentation Threshold ................... 2346
      Multi Domain Capability Implemented ....... TRUE
      Multi Domain Capability Enabled ........... TRUE
      Country String ............................ US
      First Chan Num ............................ 1
      Number Of Channels ........................ 11
    MAC Operation Parameters
      Packet Retry Limit ........................ 64
    Tx Power
      Num Of Supported Power Levels ............. 7
      Tx Power Level 1 .......................... 22 dBm
      Tx Power Level 2 .......................... 19 dBm
      Tx Power Level 3 .......................... 16 dBm
      Tx Power Level 4 .......................... 13 dBm
      Tx Power Level 5 .......................... 10 dBm
      Tx Power Level 6 .......................... 7 dBm
      Tx Power Level 7 .......................... 4 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 6
      Tx Power Assigned By ...................... DTPC
    Phy OFDM parameters
      Current Channel ........................... 6
      Channel Assigned By ....................... DCA
      Extension Channel ......................... NONE
      Channel Width.............................. 20 Mhz
      Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11
      TI Threshold .............................. -50
      Legacy Tx Beamforming Configuration ....... CUSTOMIZED
      Legacy Tx Beamforming ..................... ENABLED
      Antenna Type............................... INTERNAL_ANTENNA
      Internal Antenna Gain (in .5 dBi units).... 8
      Diversity.................................. DIVERSITY_ENABLED
      802.11n Antennas
         A....................................... ENABLED
         B....................................... ENABLED
         C....................................... ENABLED
         D....................................... ENABLED
    Performance Profile Parameters
      Interference threshold..................... 10 %
      Noise threshold............................  -70 dBm
      RF utilization threshold................... 80 %
      Data-rate threshold........................ 1000000 bps
      Client threshold........................... 25 clients
      Coverage SNR threshold..................... 12 dB
      Coverage exception level................... 25 %
      Client minimum exception level............. 3 clients
    Rogue Containment Information
    Containment Count............................ 0
    CleanAir Management Information
        CleanAir Capable......................... Yes
        CleanAir Management Administration St.... Enabled
        CleanAir Management Operation State...... Up
        Rapid Update Mode........................ Off
        Spectrum Expert connection............... Enabled
          CleanAir NSI Key.......................
          Spectrum Expert Connections counter.... 0
        CleanAir Sensor State.................... Configured
    Radio Extended Configurations
      Beacon period.............................. 100 milliseconds
      Beacon range............................... AUTO
      Multicast buffer........................... AUTO
      Multicast data-rate........................ AUTO
      RX SOP threshold........................... AUTO
      CCA threshold.............................. AUTO
Everyone's tags (1)
671
