Wireless WPA2 + AD + RSA ACE Server possible
I have a client that wants to use WPA2 authenticated to the Windows Active Directory and also has an RSA ACE Server. The goal os to provide 802.1x security with these 3 devices. I am NOT looking to USE the RSA tokens for this, only the underlying RSA RADIUS service to authenticate clients. Is this possible or do I also need a ACS server?
The alternative is to use Wireless WPA2 + AD + Windows IAS RADIUS.
Thanks for any comments,
Chris Serafin
Security Engineer
chris@chrisserafin.com
1 REPLY
Re: Wireless WPA2 + AD + RSA ACE Server possible
I would suggest that you use WPA2 with Cisco Secure ACS. You can import the existing AD database to the Cisco Secure ACS.
238
