Community Member
WiSM to ACS communication problem
Just starting to test this out and configure everything. ACS is setup with the controllers and my test user. Using LEAP (802.1x). From the controller I can ping my ACS box and ping my access point. From the vlan that the access point is configured on I can ping to my ACS box. When I go to authenticate it fails. Check the failed attempts in ACS and there is no entry, which makes me think I'm not even hitting the box. Was thinking of putting a sniffer behind the ACS box, but will I see anything? Or will it be all encrypted? If there is anything I need to post here to get more help let me know. Thanks in advance.
1 REPLY
Community Member
Re: WiSM to ACS communication problem
Also, when I take off the security. I connect and can ping everywhere with no problems. One more thing that has me a bit confused is that with the controller set to broadcast the SSID in the WLAN it won't broadcast.... atleast not that I'm seeing. Thanks again.
145
