WISM2 HA issues with VSS
I have a VSS cluster with a WISM2 in each switch.
I have configured them both for HA SSO following the documentation, however the secondary WISM2 continually goes into maintenance mode instead of joining the HA pair.
I am able to ping all of the addresses for the WISM2s from each module with the exception of the management interface on the secondary WISM2.
Can someone help?
Jason
Everyone's tags (3)
Re: WISM2 HA issues with VSS
Just for reference here is the output from both WISMs.
Primary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       LAG  99       172.16.57.249   Static  Yes    No
redundancy-management            LAG  99       172.16.57.247   Static  No     No
redundancy-port                  -    untagged 169.254.57.247  Static  No     No
service-port                     N/A  N/A      192.168.10.3    DHCP    No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
(WiSM-slot44-1) >show redundancy summary
            Redundancy Mode = SSO ENABLED
                Local State = ACTIVE
                 Peer State = UNKNOWN - Communication Down
                       Unit = Primary
                    Unit ID = 2C:54:2D:3A:XX:XX
           Redundancy State = Non Redundant
               Mobility MAC = 2C:54:2D:3A:XX:XX
Redundancy Management IP Address................. 172.16.57.247
Peer Redundancy Management IP Address............ 172.16.57.246
Redundancy Port IP Address....................... 169.254.57.247
Peer Redundancy Port IP Address.................. 169.254.57.246
Secondary
management                       LAG  99       172.16.57.248   Static  Yes    No
redundancy-management            LAG  99       172.16.57.246   Static  No     No
redundancy-port                  -    untagged 169.254.57.246  Static  No     No
service-port                     N/A  N/A      192.168.10.2    DHCP    No     No
(WiSM-slot28-1) >show redundancy summary
                Local State = MAINTENANCE
                       Unit = Secondary - HA SKU
Maintenance Mode = Enabled
Maintenance cause= Negotiation Timeout
Redundancy Management IP Address................. 172.16.57.246
Peer Redundancy Management IP Address............ 172.16.57.247
Redundancy Port IP Address....................... 169.254.57.246
Peer Redundancy Port IP Address.................. 169.254.57.247
Hall of Fame Super Gold
maintenance mode
Make sure both WiSM are running the same firmware and both IP Addresses being used are in the same VLAN.
Re:WISM2 HA issues with VSS
Did you configure the redundancy vlan on the 6500 via the WISM command?
Is the native vlan allowed on the port-channel?
Sent from Cisco Technical Support Android App
Bronze
its might be a misconfiguration on the 6k side, please make sure its configured exactly as the following two documents:
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml#vlan
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_tech_note09186a0080b7c904.shtml#configsup720
and i dont know what software version you are running, but i would recommend running 7.4.110.0
P.S. the only way out from maintenance mode is "Reboot"
468
