WLAN analyzers for 802.11
I'm having low performance problems with my Aironet WLAN, there is a software, WLAN Analyzer, that I can install in my computer, and check If there are more AP on same frecuency ?.
Thank you.
Green
Re: WLAN analyzers for 802.11
Netstumbler (www.netstumbler.com - Free)
If you're a packet-level person, there are also versions of WireShark/Ethereal that use WinPcap that can catch wireless traffic.
Note: you still need the keys to decrypt the traffic. In the case of WPA, you have to be capturing when the WPA client attempts to associate, or you won't get the initial key (needed to catch the subsequent key).
Good Luck
Scott
Yes, I'm, did you test something like this before ?.
Thank you.
201
