04-07-2014 08:53 AM - edited 07-05-2021 12:37 AM
I need to stage an AP as client, 801.x supplicant.
The WLAN use PEAP/MSCHAPv2 authentification, do you know if it is possible to do it ?
The purpose (which is mandatory) is to connect the AP (as bridge) to a switch where 4 PCs (non WLAN) are wired.
If you have some conf examples !
04-22-2014 03:11 AM
Traditionally, the dot1x authenticator/client relationship has always been a network device and a PC client respectively, as it was the PC user that had to authenticate to gain access to the network. However, wireless networks introduce unique challenges to the traditional authenticator/client relationship. First, access points can be placed in public places, inviting the possibility that they could be unplugged and their network connection used by an outsider. Second, when a repeater access point is incorporated into a wireless network, the repeater access point must authenticate to the root access point in the same way as a client does.
Note The 802.1X supplicant is available on 1130AG, 1240AG, 1250, and 1300 series access points. It is not available on 1100 and 1200 series access points.
The supplicant is configured in two phases:
•Create and configure a credentials profile
•Apply the credentials to an interface or SSID
You can complete the phases in any order, but they must be completed before the supplicant becomes operational.
Beginning in privileged EXEC mode, follow these steps to create an 802.1X credentials profile:
Use the no form of the dot1x credentials command to negate a parameter.
The following example creates a credentials profile named test with the username Cisco and a the unencrypted password Cisco:
ap1240AG>enable
Password:xxxxxxx
ap1240AG#config terminal
Enter configuration commands, one per line. End with CTRL-Z.
ap1240AG(config)# dot1x credentials test
ap1240AG(config-dot1x-creden)#username Cisco
ap1240AG(config-dot1x-creden)#password Cisco
ap1240AG(config-dot1x-creden)#exit
ap1240AG(config)#
04-22-2014 03:18 AM
Thank you for your answer. I just have to find one of the APs that you quote ;)
09-17-2014 07:51 AM
Check below deployment guide for better understanding on 802.1x and configuration examples.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Security/TrustSec_1-99/Dot1X_Deployment/Dot1x_Dep_Guide.html
