WLAN controller and CSACS
We are planning to implement cisco wireless network with LWAPP A.P's . for centralised controller we are planning cisco 3750 series integrated controller switch.
My quirey regarding ACS requirement. Please clarify Cisco 3750 integrated controller can provide in built ACS or is it required External CSACS for AAA services.
Thanking you,
Ranga Kishore
09885030063
Re: WLAN controller and CSACS
Currently there is no WLC device that can provide a built in AAA server.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Thanks for your reply. I cleared AAA quirey in WLC.
Thanking you,
Ranga Kishore
9885030063
Super Bronze
Whether you need ACS depends a lot on what security methods you plan to use.
If you use Windows XP/AD it's possible to use Windows IAS instead of ACS to achieve high levels of security using EAP-TLS or PEAP.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks for your valuable reply. Please clarify Cisco 3750G is able to support EAP-LEAP and TLS without External ACS.
What is the capable of user limitation in cisco 3750G inbuilt wireless lan controller can support for AAA services.
Thanking you,
Ranga Kishore
09885030063
once again, there is currently no WLC device that supports an integrated AAA server. You will need to get an external server.
122
