Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WLAN Guest Access logs with WLC
Hi all,
If I set up a guest access network based on WLC & WLC anchor (with or without WCS), do you know if it is possible to log the clients'sessions (we want to have dest IP/url & timestamps) ? If yes, how could we handle it ?
Thank you
Everyone's tags (4)
Re: WLAN Guest Access logs with WLC
No, you would need some other device like Websense in order to be able to view that information.  The WLCs are not going to be able to provide you with that as they do not log wireless traffic in that manner.
Lee
Ok Thanks
Problem is that I need to log clients URLs, and if I use a UTM/websense to log that traffic it is hard to get who asked for a specific URL : web authentication is made on WLC, http logging is made on UTM and there is no correlation between that two logs files.
It seems it is possible to get something like that with an architecture : WLC + NGS + ASA. Is there any easier/smaller solution (if I need to deploy such a solution in a small network)?
Thank you
Not that I know of.  Sorry...
Lee
1304
