WLC 2100 Series
Dear All,
could you give me some advice to configure wlc with 2 lwapp,
i did try to used 1 lwapp ( 1242 ag ) and it's work, but when i try to connect with 2 lwapp ( 1242 & 1131 ), i can't associated with lwapp 1131 ag, i did used same configuration for both,
need youd advice and reference guide for this issue.
thanks and regards
Re: WLC 2100 Series
Does the 1131 show up under the Wireless device list?
Did the AP that's not working come from Cisco with LWAPP software on it or was it upgraded from IOS? I have seen scenarios in which upgraded AP's will not associate to the controller. The way to fix this is to go to
the Security tab -> AP Policies and manually add the MAC address for that AP so that the controller will accept its self-signed certificate (SSC).
Please let me know if this helps.
Re: WLC 2100 Series
dear jwadleigh,
i try to do
> debug pm pki enable
to see sha 1 key hash but why it doesnt work
i need it to running SSC in controller,
any other solution to see sha 1 key in controller and why my controller cant do it
thanks and regards
292
