WLC 2504 and AIRCAP2602 problem with registracion
today i have set up a small wireless network . I use cisco wlc 2504 and three ap AIR-CAP 2602. The problem that I have is that AP won't register with wlc. I doubt that the problem is with the certificate,but I am not sure. maybe problem is related to country code.I don't know. I can ping AP from controller but it will not join. LWAPP image version 7.6.120.0 ,
 This is log from AP:
Jun  7 01:59:24.679: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Jun  7 01:59:24.679: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
Jun  7 01:59:34.679: %CAPWAP-3-ERRORLOG: Go join a capwap controller
Aug 19 15:12:05.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.25 peer_port: 5246
Aug 19 15:12:07.411: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.25 peer_port: 5246
Aug 19 15:12:07.411: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.25
Aug 19 15:12:07.411: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
Aug 19 15:12:07.411: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
Aug 19 15:12:07.411: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
Aug 19 15:12:07.411: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 192.168.1.25
Aug 19 15:12:25.575: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(UNKNOWN_MESSAGE_TYPE (5)
Aug 19 15:12:25.575: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
can someone help me with this problem?
2 ACCEPTED SOLUTIONS
Please verify :http://www
VIP Purple
did you configured the IP
did you configured the IP helper command on SVI interface ?
check the DHCP proxy on wlc.
controller > Advanced > DHCP and enable the proxy setting.
Dont forget to rate helpful posts
Is the time set correctly on
Is the time set correctly on the WLC? There could be a problem with the date and time on the certificates used by the controller.
thanks foe replay. Time is ok
thanks foe replay.
Time is ok, clock andtime zone is the same on wlc and ap.
VIP Purple
can you paste the output oif
can you paste the output oif these commands:
sh version from AP:
sh sysinfo from WLC
also paste the complete bootup process from AP console.
thank all for help .problem
problem was contry code.
But now I have another , when I connect to my network lap top does'n get IP address . Dhcp server iz running cisco router. .
VIP Purple
265
