Community Member
WLC 2504 - French characters for guest web login page
Good day,
I have recently installed a WLC 2504 and I have the following issue:
When I modify the text for the web login page (Under security/Web Auth/Web Auth page), if I use french caracters such as (é, è, à, etc...) in the message body, it does not show up correctly on users computers. As we're a bilingual country, I must put a bilingual text message. Are there any settings or workaround out there to rectify this?
We're on version 7.2.103.0
Eric
Everyone's tags (5)
Hall of Fame Super Silver
Re: WLC 2504 - French characters for guest web login page
You might want to try to create a custom webauth page and upload that to the wlc.
Scott Fella
Sent from my iPhone
-Scott
Here is a link
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70users.html#wp1075664
-Scott
Community Member
Thanks Scott, I'll have a look at the documentation.
Right after sending this post, I tried typing the actual HTML code for the character instead and it seems to be working. I'm curious about custom webauth page, we may be able to customize it more than we thought we could do.
Cheers,
Eric
You can download a WeAuth bundle from CCO under the controller you have.  Or you can pull the source code from that page on the WLC and work off of that.  When you have to .tar up the file, if you are using Windows, 7-zip works well.
-Scott
3409
