WLC 2504 sudden network instability
we're running a WLC 2504 with two SSIDs on it. It is connected to to a small PoE switch. Standard untagged vlan. A handfull APs connected to it. No DHCP, the APs have all static IP addresses.
All of a sudden we're having a number of issues with the network connection:
APs restarting
The APs restart every now and then reporting that their IP is being used by another device. Looking through the logs there are two MAC addresses that are reported as using the APs IP address. These two MAC addresses have unknown vendor IDs.
Warning: AP with Base Radio MAC f8:72:ea:7c:9d:e3 has found  its IP Address 0.2.146.0 being used by a machine with MAC
Address  04:c6:f8:40:00:00 (The other mac that is reported is 04:cc:90:40:00:00)
AP 'AP5', MAC: 0c:68:03:dd:1b:80 disassociated previously due to Link Failure.  Uptime: 4 days, 00 h 48 m 50 s . Reason: Capwap WTP Event request.
So: There are two MACs that use the IP addresses of 7 APs?!?! And there is no vendor to be found for these MACs?
Ping timouts on the webGUI and CLI
I have a ping running on the IP for managing the device. This is running fine for ages. As soon as I connect via webGUI or CLI I lose packets. Get timeouts etc. some packets get through some don't. More of the latter. So ping is fine but any other traffic seems to be impacted heavily.
What we have done for troubleshooting
Checked duplex/speed settings of the interfaces. Everything ok.
Connected to another switchport. Same.
Changed the IP address of the management port. Same.
Swapped places with a laptop with the same IP address --> Worked fine.
Plugged in a completely new device, installed the latest firmware (7.6) and uploaded the config from the other one. Same.
Restarted the default gateway for the subnet the controler is on.
So now we're at the end of our knowledge. It seems to be a non-physical network issue, but we're a small team and no one has changed anything they say :-/
Any ideas what we could check next?
Kat
VIP Purple
HI Kat,
First of all :
This error shows that other machine with mention mac address used this IP. The other machine may have manually configured the NIC.  Track down that host and take it off the network.
Please paste more logs from AP to know the root cause.
Hall of Fame Super Silver
One thing to be aware is that even if you have a static address on the AP. if it reboots and can't find the WLC, it will revert to DHCP.  If you don't have dhcp for the subnet the AP's are connected on, the will just fail.  This would mean that connectivity to the WLC broke and made these AP's fallback to DHCP.  In this state, your AP's would need to be rebooted and you need to make sure that they join the WLC.  It's almost better to add a dhcp scope and use mac reservations so that these AP's can get the same address all the time.
Maybe you need to post your show run-config and your switchport config so we can verify if your configuration is okay.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
thanks for your suggestions. It's hard to find those two MAC addresses. As they seem to be virtual I cannot get a hint from the vendor ID. A show mac-address table on the switch the WLC is connected to doesn't show those two
I found an error in the WLC AP config. AP1 had the same IP as AP5 and a wrong netmask. I changed that. Unfortunately that doesn't solve our problem.
Here are some more messages from the WLC's log:
AP 'AP3', MAC: 0c:68:03:dd:34:00 disassociated previously due to Link Failure.  Uptime: 4 days, 15 h 04 m 15 s . Reason: Capwap WTP Event request.
AP Disassociated. Base Radio MAC:0c:68:03:dd:34:00
AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:0c:68:03:dd:34:00  Cause=Heartbeat Timeout Status:NA
AP 'AP3', MAC: 0c:68:03:dd:34:00 disassociated previously due to Link Failure.  Uptime: 4 days, 15 h 00 m 45 s . Reason: Capwap WTP Event request.
RF Manager updated TxPower for Base Radio MAC: 0c:68:03:dd:34:00 and slotNo: 0.  New Tx Power is: 2
AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:0c:68:03:dd:16:e0  Cause=Max Retransmission Status:NA
IDS Signature attack detected. Signature Type: Standard, Name: Deauth flood,  Description: Deauthentication flood, Track: per-signature, Detecting AP Name:  AP7, Radio Type: 802.11b/g, Preced: 9, Hits: 500, Channel: 6, srcMac:  C2:9F:DB:21:47:60
This is the sh run-config of our WLC including one AP:
>show run-config
System Inventory
NAME: "Chassis"    , DESCR: "Cisco 2500 Series Wireless LAN Controller"
PID: AIR-CT2504-K9,  VID: V01,  SN: PSZ17381EPZ
Burned-in MAC Address............................ 50:17:FF:27:12:80
Maximum number of APs supported.................. 15
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.110.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... UK-BRI-WFAPC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 172.17.128.12
Last Reset....................................... Power on reset
System Up Time................................... 4 days 0 hrs 46 mins 6 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... GB  - United Kingdom
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +20 C
External Temperature............................. +25 C
Fan Status....................................... 4000 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 6
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
AP Bundle Information
Primary AP Image    Size
ap1g2            9568
ap3g1            11288
ap3g2            11196
ap801            7164
ap802            8568
c1130            5072
c1140            9416
c1250            6944
c1520            8044
c602i            3736
Secondary AP Image    Size
ap3g1            5792
ap801            5192
ap802            5232
c1100            3084
c1130            4964
c1140            4992
c1200            3364
c1240            4812
c1250            5504
c1310            3136
c1520            6404
c3201            4324
c602i            3716
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
Strong Password Check Features:
     case-check ...........Enabled
     consecutive-check ....Enabled
     default-check .......Enabled
     username-check ......Enabled
Network Information
RF-Network Name............................. RFGROUP
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 0.0.0.0
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
MLD snooping................................ Disabled
MLD timeout................................. 60 seconds
MLD query interval.......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth CMCC Support ...................... Disabled
Web Auth Redirect Ports .................... 80
Web Auth Proxy Redirect  ................... Disable
Web Auth Captive-Bypass   .................. Disable
Web Auth Secure Web  ....................... Enable
Fast SSID Change ........................... Disabled
AP Discovery - NAT IP Only ................. Enabled
IP/MAC Addr Binding Check .................. Enabled
CCX-lite status ............................ Disable
oeap-600 dual-rlan-ports ................... Disable
oeap-600 local-network ..................... Enable
mDNS snooping............................... Disabled
mDNS Query Interval......................... 15 minutes
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A
2  Normal  Forw Enable  Auto       100 Full   Up     Enable  N/A
3  Normal  Forw Enable  Auto       1000 Full  Up     Enable  Enable  (Power Off)
4  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
AP Summary
Number of APs.................................... 7
Global AP User Name.............................. Not Configured
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots  AP Model              Ethernet MAC       Location          Port  Country  Priority
AP7                  2     AIR-CAP1602I-E-K9     f8:72:ea:e4:9a:81  default location  1        GB       1
AP1                  2     AIR-CAP1602I-E-K9     f8:72:ea:7c:9d:e3  default location  1        GB       1
AP3                  2     AIR-CAP1602I-E-K9     f8:72:ea:e4:9c:57  default location  1        GB       1
AP6                  2     AIR-CAP1602I-E-K9     f8:72:ea:e4:9a:90  default location  1        GB       1
AP2                  2     AIR-CAP1602I-E-K9     f8:72:ea:7c:9b:63  default location  1        GB       1
AP4                  2     AIR-CAP1602I-E-K9     f8:72:ea:e4:9a:9b  default location  1        GB       1
AP5                  2     AIR-CAP1602I-E-K9     f8:72:ea:e4:9a:cb  default location  1        GB       1
AP Tcp-Mss-Adjust Info
AP Name              TCP State  MSS Size
AP7                  disabled   -
AP1                  disabled   -
AP3                  disabled   -
AP6                  disabled   -
AP2                  disabled   -
AP4                  disabled   -
AP5                  disabled   -
AP Location
Total Number of AP Groups........................ 0
Site Name........................................ default-group
Site Description.................................
NAS-identifier................................... UK-BRI-WFAPC
AP Operating Class............................... Not-configured
RF Profile
2.4 GHz band.....................................
5 GHz band.......................................
WLAN ID          Interface          Network Admission Control          Radio Policy
1               corporate            Disabled                          None
2               dirtynetwork         Disabled                          None
3               dirtynetwork         Disabled                          None
RF Profile
Number of RF Profiles............................ 0
Out Of Box State................................. Disabled
RF Profile Name                    Band     Description                         11n-client-only
AP Config
Cisco AP Identifier.............................. 15
Cisco AP Name.................................... AP7
Country code..................................... GB  - United Kingdom
Regulatory Domain allowed by Country............. 802.11bg:-E     802.11a:-E
AP Country code..................
AP Regulatory Domain............................. -E
Switch Port Number .............................. 1
MAC Address...................................... f8:72:ea:e4:9a:81
IP Address Configuration......................... Static IP assigned
IP Address....................................... 172.17.128.24
IP NetMask....................................... 255.255.128.0
Gateway IP Addr.................................. 172.17.128.1
Name Server......................................
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Disabled
Ssh State........................................ Disabled
Cisco AP Location................................ default location
Cisco AP Floor Label............................. 0
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................
Primary Cisco Switch IP Address.................. Not Configured
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ....
............................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ..
....................... kern
S/W  Version .................................... 7.4.110.0
Boot  Version ................................... 15.2.2.0
Mini IOS Version ................................ 7.4.1.37
Stats Reporting Period .......................... 180
Stats Collection Mode ........................... normal
LED State........................................
Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-CAP1602I-E-K9
AP Image...............................
.......... C1600-K9W8-M
IOS Version...................................... 15.2(2)JB2$
Reset Button..................................... Enabled
AP Serial Number................................. FGL1725W7F7
AP Certificate Type.............................. Manufacture Installed
AP User Mode..................................... AUTOMATIC
AP User Name..................................... Not Configured
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system loggi
ng host..................... 255.255.255.255
AP Up Time....................................... 3 days, 23 h 26 m 50 s
AP LWAPP Up Time................................. 0 days, 00 h 14 m 12 s
Join Date and Time............................... Tue Jan 28 18:11:43 2014
Join Taken Time.................................. 0 days, 00 h 11 m 41 s
Attributes for Slot  0
    Radio Type................................... RADIO_TYPE_80211n-2.4
    Administrative State ........................ ADMIN_ENABLED
    Operation State ............................. UP
    Radio Role .................................. ACCESS
    Radio Mode .................................. Local
    CellId ...................................... 0
    Station Configuration
      Configuration ............................. AU
TOMATIC
      Number Of WLANs ........................... 3
      Medium Occupancy Limit .................... 100
      CFP Period ................................ 4
      CFP MaxDuration ........................... 60
      BSSID ..................................... 0c:68:03:dd:16:e0
      Operation Rate Set
        1000 Kilo Bits........................... MANDATORY
        2000 Kilo Bits........................... MANDATORY
        5500 Kilo Bits........................... MANDATORY
        11000 Kilo Bits.......................... MANDATORY
        6000 Kilo Bits........................... SUPPORTED
        9000 Kilo Bits........................... SUPPORTED
        12000 Kilo Bits.......................... SUPPORTED
        18000 Kilo Bits.......................... SUPPORTED
        24000 Kilo Bits.......................... SUPPORTED
36000 Kilo Bits.......................... SUPPORTED
        48000 Kilo Bits.......................... SUPPORTED
        54000 Kilo Bits.......................... SUPPORTED
      MCS Set
        MCS 0.................................... SUPPORTED
        MCS 1.................................... SUPPORTED
        MCS 2.................................... SUPPORTED
        MCS 3.................................... SUPPORTED
        MCS 4.................................... SUPPORTED
        MCS 5.................................... SUPPORTED
        MCS 6.................................... SUPPORTED
        MCS 7.................................... SUPPORTED
        MCS 8.................................... SUPPORTED
        MCS 9.................................... SUPPORTED
        MCS 10................................... SUPPORTED
        MCS 11................................... SUPPORTED
        MCS 12..
        MCS 13................................... SUPPORTED
        MCS 14................................... SUPPORTED
        MCS 15................................... SUPPORTED
        MCS 16................................... DISABLED
        MCS 17................................... DISABLED
        MCS 18................................... DISABLED
        MCS 19................................... DISABLED
        MCS 20................................... DISABLED
        MCS 21................................... DISABLED
        MCS 22................................... DISABLED
        MCS 23................................... DISABLED
      Beacon Period ............................. 100
      Fragmentation Threshold ................... 2346
      Multi Domain Capability Implemented ....... TRUE
      Multi Domain Capability Enabled ........... TRUE
      Country String ............................ GB
      Configuration ............................. AUTOMATIC
      First Chan Num ............................ 1
      Number Of Channels ........................ 13
    MAC Operation Parameters
      Packet Retry Limit ........................ 64
    Tx Power
      Num Of Supported Power Levels ............. 4
      Tx Power Level 1 .......................... 16 dBm
      Tx Power Level 2 .......................... 13 dBm
      Tx Power Level 3 .......................... 10 dBm
      Tx Power Level 4 .......................... 7 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 3
      Tx Power Assigned By ...................... DTPC
    Phy OFDM parameters
      Current Channel ........................... 6
      Channel Assigned By ....................... DCA
      Extension Channel ......................... NONE
      Channel Width.............................. 20 Mhz
      Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11,12,
        ......................................... 13
      TI Threshold .............................. -50
      Legacy Tx Beamforming Configuration ....... CUSTOMIZED
      Legacy Tx Beamforming ..................... ENABLED
      Antenna Type............................... INTERNAL_ANTENNA
      Internal Antenna Gain (in .5 dBi units).... 8
      Diversity.................................. DIVERSITY_ENABLED
      802.11n Antennas
         A....................................... ENABLED
         B....................................... ENABLED
         C....................................... ENABLED
    Performance Profile Parameters
      Interference threshold..................... 10 %
      Noise threshold............................  -70 dBm
      RF utilization threshold................... 80 %
      Data-rate threshold........................ 1000000 bps
      Client threshold........................... 12 clients
      Coverage SNR threshold..................... 12 dB
      Coverage exception level................... 25 %
      Client minimum exception level............. 3 clients
    Rogue Containment Information
    Containment Count............................
    CleanAir Management Information
        CleanAir Capable......................... No
    Radio Extended Configurations
      Beacon period.............................. 100 milliseconds
      Beacon range............................... AUTO
      Multicast buffer........................... AUTO
      Multicast data-rate........................ AUTO
      RX SOP threshold........................... AUTO
      CCA threshold.............................. AUTO
VIP Purple
HI Katja,
I will suggest to craete a dhcp pool on Swicth.
Example:
vlan 80 is the management vlan in this example.
ip dhcp excluded-address 10.xx.80.1 10.xx.80.100
ip dhcp excluded-address 10.xx.80.115 10.xx.80.254
ip dhcp pool WirelessLAN
   network 10.xx.80.0 255.255.255.0
   default-router 10.xx.80.254
   option 43 ip 10.xx.80.1 --->WLC IP
   lease 3
Where AP connected:
interface FatEthernet1/xx
switchport access vlan 80
switchport mode access
After more days of troubleshooting I found a reverse dns entry for one of the WLCs interfaces, deleted it. Also two APs had the same IP. Since no one had touched the device since its installation in October, this issue must have existed ever since.
So I got rid of the log messages with the IP conflict. Still the WLC was losing at least 50% of its packets resulting in APs restarting every now and then. The problem is somewhere in the transition between our two subnets, so I swapped IP addresses of the management interface including APs and the interface into our LAN. Works fine now as a workaround.
Thanks for your help.
Katja
VIP Purple
Glad that you finally resolved the issue.
But I will recommand you to use DHCP pool on swicth for APs.
Please rate helpful posts accordingly.
1351
