WLC 2504 web auth
smolz
Level 4
Level 4
I have a setup with a 2504 with 3 interfaces in use: 1 for ap management, one going to the internal network and 1 that is connected directly to a dmz interface for guest use.
My question is how to get the web auth page to display?  I have configured it to display using None for Layer 2 and "Web Policy and Authentication" for the layer 3.
My clients get an ip from the ASA interface in the dmz but when trying to open a page, nothing is diplayed.
Scott Fella
In order to display the webauth, the wlc will hijack the home page of the user and will try to resolve the page first. If the page can be resolved, then you will get the splash page. If not, then no. So first make sure DNS is working and also make sure the users home page is not an https site but they are using http. Plug a wired device onto the same vlan for the guest wireless in the DMZ and verify that it works for a wired device.
-Scott
